-   -   Crankshaft pulley interchange (http://forums.pelicanparts.com/911-engine-rebuilding-forum/1043783-crankshaft-pulley-interchange.html)
eastbay 10-28-2019 06:39 PM
What crank pulleys interchange over the years? Found a few threads that show pulley diameters, but nothing on crank fitments.
Flat6pac 10-29-2019 04:36 AM
The pulleys to the crank are interchangeable through 3.2 with the locator pin to the left side.
3.6 moved the locator pin to the right side.
The question becomes which fan belt works with the combination of pulleys and fan
Bruce
eastbay 10-29-2019 04:13 PM
So the only difference is the 3.2 pulley has no timing marks other than Z1 and 5
Flat6pac 10-29-2019 07:54 PM
The 3.2 advance is taken care of by the DME
It is marked every 120 degrees
Bruce
Trackrash 11-01-2019 05:23 PM
What are you trying to do? Change the fan speed or back date the fan pulley? Fan speed and air flow were discussed once upon a time here. Perhaps someone,(Bill?) remembers the thread.
