-   -   Ajusting CR on 2.5 conversion (http://forums.pelicanparts.com/911-engine-rebuilding-forum/1044772-ajusting-cr-2-5-conversion.html)
Anglocanadian 11-10-2019 06:37 AM
Going with the Bruce Anderson 2.2 to 2.5 conversion, he describes taking .04" from the heads to up the CR. I find that this would not leave enough material to angle out the combustion chamber to 90mm.
Is there any reason I cant skim the top of the cylinders ? I have to put the ring grooves in anyway.
Greatly appreciate any advice.
faapgar 11-10-2019 06:56 AM
90mm
You need a slight bevel in the head for the larger 90mm piston.If it is a 90mm 2.7 RS style you need a longer rod to get the CR to 8.5.JE or others can move the pin location up or down to get your desired CR.Ciao Fred
Anglocanadian 11-10-2019 11:01 AM
Yes I have already beveled the heads to 90mm , after calculation the CR I figure removing .04" will give me 8.16:1 which is better than described in the book also the deck height is 2.5mm at the moment so a 1mm reduction would be perfect.
Something that occurred to me was rather than taking .40 off the chain housing to match why not make a custom .40" shim to insert between heads and cam housing ?
I really don't want to go to the expense of new rods.
ed mayo 11-10-2019 08:28 PM
We did the cam housing shims years ago, they work just fine.
Geneulm 11-11-2019 03:34 AM
Can’t you stretch the rod by machining an offset into the top bushing?
Trackrash 11-11-2019 11:22 AM
On my old 2,5 I was able to get to 8.4 CR using Mahle RS P&Cs. .040" was taken off the heads and I omitted the cylinder base gaskets. It was a nice running motor using 36mm ports and E cams.
Anglocanadian 11-11-2019 03:04 PM
Thank for the conformation on the shim Ed , it did seem to me to be better than running into problems with the chains.
If cost was not an issue i would send off the rods for adjustment it is the simplest solution.
But my situation is i have access to basic machinery (lathe,Mill and surface grinder no jig grinder or hone) and my labor is free, and taking 1mm of the top of the cylinders is a fairly easy operation. I don't want to drop the deck height below 1mm so i think i will leave the bottom gasket in
Trackrash 11-11-2019 03:34 PM
Won't that throw off the rocker to valve geometry?
On my motor I just enlarged the three holes in the cam sealing flange so it would align properly. Worked fine.
dannobee 11-11-2019 04:33 PM
Re: chain housings, just omit the gasket and use threebond.
Re: rocker geometry. I think he meant 0.040". In that case, no harm, no foul. Regrinding the cam to a lower base circle will take off more than that, and in any case, a lash cap would fix any geometry issue.
Why not take 0.040" off of the bottom of the cylinder instead of the top? Since I'm really lazy, that's what I would do instead of fiddling with the taper and/or groove.
Anglocanadian 11-11-2019 06:20 PM
I wanted to keep the chain housing in its correct position so there is no problem or the chain tension
The barrel's came without CE grooves so I need to machine them in as well on the top.
911pcars 11-13-2019 12:37 PM
On a past rebuild/build from 2.5 > 2.7, the cam wasn't centered in the cam housing oil seal. I compensated by milling an appropriate amount from the cam box sealing surface.
Moving further along, with the cam housing/cylinder head/cylinder stack closer to the crankshaft center line, the result created excessive timing chains slack, too much slack for the tensioner range. I ended up sourcing oversize idler sprockets to restore the tension range. Worked fine until I sold the engine at 23K miles.
Sherwood
Anglocanadian 11-13-2019 02:37 PM
Sherwood
That,s exactly what i intend to avoid by using the shims to keep the cams in there original position.
In fact I have already made a set !
http://forums.pelicanparts.com/uploa...1573687876.jpg
faapgar 11-13-2019 03:34 PM
Compression Ratio
First you have to consider the age of the motor.Is this the 1st or 2nd or 3rd valve job.When the valve seats are cut and the valve resurfaced things change.I have redone motors where with 10.5 they were actually 7.9 to 1.When you start with an unknown motor you CC it.Then you have a starting point.Assumption does not work well when you play with these.Ciao Fred
faapgar 11-13-2019 03:54 PM
Used stuff with broken head studs and other maladies
Do you ever wonder about the side effects of pulled head studs or broken head studs?You should sign up for Boyt911sc engine rebuilding class in April.Tony has asked me to help.I will do one week with 2 schools.He is a wonderful person who will be 77 soon.No book will ever cover this school.Ciao
Trackrash 11-13-2019 05:12 PM
Very interesting. I can't wait to see how those work.
What material did you use and how did you cut them out?
Anglocanadian 11-13-2019 06:21 PM
I got the local metal supply store to cut me 6 pieces of .04" aluminum and then marked out and spotted through the stud holes. After they are fitted over the studs simply scribe around the areas to be cut out and then mill and dremel away.
I did get fancy and media blasted them for a nice finish :)
dannobee 11-14-2019 09:23 AM
I think the spacers are supposed to look like thishttp://forums.pelicanparts.com/uploa...1573755795.jpg
Walt Fricke 11-14-2019 02:30 PM
Either should work. I'd consider making 12 singles - should save setup costs at your friendly local hydrocutter?
Anglocanadian 11-14-2019 02:49 PM
They actually do hydro cutting at the metal supply shop I got my aluminum from.The time involved in measuring all the stud centers and then the extra cost of the cutting wasn't justifiable for a one off project.
I cant see the point of putting three together , your throwing away half the material and the connecting strips don't add any support .
Henry Schmidt 11-19-2019 05:06 PM
A few years back, we were able to make 10.25:1 compression with RS pistons on a short stroke 2.5.
The magic was in the heads.
http://forums.pelicanparts.com/uploa...1574215407.jpg
http://forums.pelicanparts.com/911-engine-rebuilding-forum/434823-old-school-twist.html
http://forums.pelicanparts.com/uploa...1574215565.jpg
Anglocanadian 11-19-2019 06:38 PM
Seems like the "spacer" solutions been around for a while and i thought I had come up with something new !
The deck height must have been borderline with those heads if you had to use a spacer ?
faapgar 11-20-2019 04:58 AM
Supertec 2.5
Henry,I like the head treatment on the 2.5.Very slick.Keeps the charge in the center for better flow.
Henry Schmidt 11-20-2019 07:46 AM
Our big concern was flow around the valves (valve shrouding). Our thinking was smaller valves or high lift cams. Next time around I believe we will polish the chamber to improve flow....if there is a next time.
In this instance we went with high lift cams. @ 490 intake lift the heads flowed better than expected. Bill @ Extreme was surprised at the flow with all things considered.
jm993rs 11-26-2019 04:46 AM
Very very interesant .....:mad::eek::eek:
r lane 12-03-2019 11:09 AM
I suppose at some point you can have too small of a chamber that will not accommodate the air and fuel charge available. Don't know what issues would materialize from that condition, cavitation, scrambled fuel mixture? Anyone have a base formula for calculating optimum cylinder head volume based on overall displacement. Obviously other factors have to be considered, but a base number.
r lane 12-03-2019 11:15 AM
I wrote prior to thinking. Your desired compression ratio will determine that relationship.
911pcars 12-03-2019 11:40 AM
High compression ratios as a result of piston or combustion chamber shape is beneficial for both power and fuel mileage - up to a point, as long as moving parts don't collide and/or detonation isn't the result. Fuel octane, ignition advance settings, altitude, ambient air temperatures and operating conditions are variables that will greatly affect engine longevity. Pay attention to those conditions.
As a rough estimate, depending on the above plus the physical engine specs, compression ratios approaching/in the range of/exceeding 10:1 may/will require twin plug ignition or other strategies to mitigate destructive detonation.
Some ATF, 1/4" sheet plastic, a graduated burette, an assembled cylinder head and a calculator can be used to calculate the physical CR.
http://forums.pelicanparts.com/uploa...1575405381.jpg
https://www.google.com/search?q=measure+compression+ratio&client=firefox-b-1-ab&sxsrf=ACYBGNTZVuVcyy39xKIr6Kc99WS2UzWoBA:157540 5485933&source=lnms&sa=X&ved=0ahUKEwimxPbiqprmAhVD rZ4KHb7yDh4Q_AUIDCgA&biw=1076&bih=674&dpr=2.22
Sherwood
Walt Fricke 12-04-2019 10:36 AM
I have just mocked up one piston/cylinder/head, run the piston to TDC, measured what the VTDC is directly by filling the chamber through the spark plug hole (engine on stand appropriately tilted, and a modified spark plug with a clear plastic tube with an X extra CC mark on it, as a filler funnel). It is a quick and dirty, and probably not the way to CC every hole to get that super exact match. But seems to work - the MMO didn't leak by the rings. I've not compared the result to that achieved in the usual way, but I can't see why it would be off.
Anglocanadian 12-07-2019 08:29 AM
I did mine in the same way through the plug hole, the C/R is in the low 8's and the deck height 1mm . I figure that's about as good as it gets without going "super modified" as Henry has done.
I am using the QSC iron barrels and pistons as the engine is a low budget Sunday afternoon cruiser not a track day car.
