-   -   mounting cam gear question (http://forums.pelicanparts.com/911-engine-rebuilding-forum/104509-mounting-cam-gear-question.html)
cosmo 03-31-2003 09:08 AM
After installing the cam sprocket over 3 shims and the main washer there is only about 1/16" showing on the cam for the chain gear to mount. Is this normal?? Seems a little odd to me.
Cosmo:confused:
ChrisBennet 03-31-2003 11:36 AM
The chain sprocket will not slide completely onto the cam shaft but it should slide on more than 1/16". Make sure the inner gear is pressed on all the way.
-Chris
Wayne 962 03-31-2003 11:39 AM
Which sprocket are you talking about? The big one, or the smaller one?
-Wayne
john walker's workshop 03-31-2003 07:00 PM
that would be because the cam is not up against the thrust plate. pry it toward the plate with a screwdriver behind whatever lobe you can get a bite on. they move easily.
