97mm cast iron cylinders
Has anyone had any experience replacing the Nikasil 97mm cylinders with cheaper cast iron units?
I am particularly interested if it is possible do it without machining heads and case.
Old 12-08-2019, 06:54 PM
Mmmmm, 1968 technology so Porsche could produce a cheaper version of the 911 and you desire to copy the economy.
You should try to find a good used cast cylinder, heat killed most of them
Bruce
Old 12-11-2019, 07:24 PM
Bruce
+1 The Nikasil cylinders are such a Great Leap Forward over the iron ones. If yours are worn, why not have yours replated?
1990 964 Coupe
1986 Carrera 3.2 Targa
Old 12-13-2019, 06:55 AM
Jon from EBS Racing here. Would not recommend 97mm cast iron cylinders. Replating your cylinders is really the best way to go and very reasonable @ $990/set vs a new piston & cylinder set. If you don't have good cores we can supply those as well. Call or email me jon@ebsracing.com if you would like more details.
Thanks!
Jon
Tel: 775 673 1300
Email: jon@ebsracing.com
www.ebsracing.com
Old 12-13-2019, 09:02 AM
