-   -   Ring Compressor (http://forums.pelicanparts.com/911-engine-rebuilding-forum/104655-ring-compressor.html)
red-beard 04-01-2003 07:23 AM
Ring Compressor
Does Pelican sell the ring compressor tool? I can't seem to find them in the catalog.
James
911pcars 04-01-2003 06:53 PM
The tool manufacturer, Lisle, used to sell a take-apart type ring compressor with a plier-type ratcheting tool to compress and hold the band. They made it for Corvairs/VWs. Corvair pistons are about the same size as the Pcar. Check your local auto parts tool catalog.
Sherwood Lee
http://members.rennlist.org/911pcars
Doug Zielke 04-01-2003 06:58 PM
That's the one I have. It worked very well. Bought it at NAPA.
snowman 04-04-2003 09:07 PM
I used a std hose clamp. The only shortfall is that you may have to use it two times to get the piston fully installed.
First clamp the first couple of rings, slide on the cylinder, past the first rings. Move the clamp if necessary to the final ring and slide on the cylinder. back off the clamp completely and unwind it around the piston.
911pcars 04-04-2003 11:08 PM
Snowman,
A hose clamp works as well. I would suggest using a hose clamp that has a solid band, not the type with the slots that go all the way through. The slots could nick the ring when tightening the clamp.
Sherwood Lee
snowman 04-07-2003 10:29 AM
Sherwood,
Thank you. Thats the only kind of clamps I use and I tend to forget about the junk stuff out there.
ChrisBennet 04-07-2003 12:04 PM
Gee, now I feel embarrassed to admit I use a fancy Hazet ring compressor. I use to use the simple-band-that-you-squeeze-together-with-pliers types but my tool source (EBS) didn't have them for 98mm pistons (3.4L). The Hazet tool is pretty nice though...
-Chris
john walker's workshop 04-07-2003 12:18 PM
don't be embarassed, the hazet is the cat's ass. hose clamps? come on now. http://forums.pelicanparts.com/uploads/IMG_0900.JPG
Wayne 962 04-07-2003 12:34 PM
Hose clamps? You've got to be kidding. That's almost as bad as the 2x4...
While I don't recommend spending $130 on a Hazet ring compressor, I do recommend the following:
For assembling the pistons into the cylinders, you will need a ring compressor. With so much room for error in this process, I do not recommend purchasing a cheap ring compressor. Placing the pistons in your cylinders is a very delicate process, and if done incorrectly can easily lead to a broken ring, which will result in yet another teardown of the engine. There are $3 pieces of sheet steel for sale out there that are sold as ring compressors. I do not recommend using these, as it adds one more element of difficulty to the equation. A good quality ring compressor will cost about $20-$35 and will include a specially designed set of pliers whose specific purpose is to latch onto and compress the steel ring band. This type of compressor is much easier to use than the simple band one, and will reduce the chances that you will break a ring. Since the tool is relatively inexpensive when compared to the risks involved, I fully recommend that you purchase a good quality one.
Compressing your rings is one of the most trickiest processes on the 911 engine. If you don't use the proper tool, you may end up with one of these:
http://forums.pelicanparts.com/uploads/broken_ring.JPG
-Wayne
Wayne 962 04-07-2003 12:35 PM
That said, I was not happy with the ring compressor that I purchased for the new book. The sizes of the rings weren't quite fitting right. I'm looking for a better one for Pelican to carry...
-Wayne
cowtown 04-07-2003 04:48 PM
I used a hose clamp. No problem. I would like to have one of those "cat's asses" though - they look cool.
jgparker 04-07-2003 05:28 PM
I have used Craftsman ratcheting ring compressor with very good results, but you can only use it if you are installing the pistons in the Jugs before you put the piston on the rod.
Hose clamp or Hazet, this is a tricky operation. I recommend practicing with an old piston, rings and jug, if at all possible. Even Wayne has broken a ring in this operation, but then again, he did not have a cat's ass.
Doug Zielke 04-07-2003 07:36 PM
A very good idea, and exactly what I did using my old P & C set.
By the time I was ready to go with my new Mahles, I had some confidence I could do the job without breaking anything.
As far as the hose clamp thing goes....after spending a few thousands on a rebuild, what's the sense of *that*?
Jim Sims 04-07-2003 07:36 PM
Snap-On Blue-Point RCL-30 2-1/8" to 5" range. Cost ~$19.00; easy to use on the bench plus unlatches to wrap around to compress rings in-situ. Jim
jgparker 04-08-2003 05:57 AM
Anyone ever try the Snap-on RCW60? It looks to have most of the features of the Hazet, but at $14. At that price, I have to try it.
http://buy.snapon.com/catalog/PRO.asp?tool=all&Group%5FID=1593&Group%5FName=Ring +Compressors&Sub%5FCat%5FID=1468745&Sub%5FCat%5FNa me=Ring+Compressors&Cat%5FID=1468743&Cat%5FNAME=Pi ston&store=snapon%2Dstore
snowman 04-09-2003 04:20 PM
I have access to all the ring compressors mentioned, and several more. I have tried all of them and the hose clamp works best of all, no kidding. The only down side is it will not catch all the rings at once. Maybe if I were not so cheep and bought two of them it would be easier.
I only use high quality solid stainless steel hose clamps. Do not attempt this with the ones with slots everywhere.
cowtown 04-09-2003 04:29 PM
...but make sure the 2x4 is properly positioned below your engine BEFORE using the hoseclamp!!! :D
john walker's workshop 04-09-2003 07:13 PM
stone knives, bearskins, hose clamps, 2x4s, hammers, axes, all the proper tools to do the job right.
Doug Zielke 04-09-2003 07:20 PM
Ahh, John.....I hate to be picky, but you forgot the corkscrew! ;)
Wayne 962 04-09-2003 07:22 PM
I'm going to be adding the ring compressor tool very shortly...
-Wayne
