-   -   2.4 Engine to ST Speces (http://forums.pelicanparts.com/911-engine-rebuilding-forum/1048182-2-4-engine-st-speces.html)
Porsche2217 12-23-2019 05:06 PM
Hello guys,
I need your knowledge to budget my 2.4 engine to ST specs. The car is a 1972 911T with a ST body, the engine is a stock engine but I will like to converted to an ST spec.
Plesase let me know a ball park for this kind of engine build.
Thank you.
targa72e 12-24-2019 01:08 PM
I am going to say $15-20K if you do it yourself. I am selling a MFI 2,4 I built with S pistons and E cams. I totaled up the parts and machine work and had $11K+ in cost and am sure I did not total up everything. My case was in pretty good shape and did not need to be narrowed and re-bored (more cost) That price doesn't include any cost for assembly, cleaning making stuff look nice etc. If you keep the MFI You will also need to have additional MFI work done, probably another $4K. Pricing estimates below.
Link to another thread with similar question.
http://forums.pelicanparts.com/911-engine-rebuilding-forum/1040099-1973-2-4t-engine-rebuild-diy-cost.html
inserts 390
oil bypass 175
deck 150
line hone 200
crank 200
rods 420
valve job 420
valves 300
surface 220
valve guides 100
rockers 500
P&C 3500
tensionor kit 890
sc oil pump 250
chains 100
sprockets 300
idlers 627
e cams 1000
rod bearings 275
rod bolts 130
main bearings 130
gasket set 220
john
Porsche2217 12-24-2019 07:16 PM
Thank you so much Targa72e. I have a better idea to make the budget.SmileWavy
BITYGA 12-30-2019 04:48 AM
The car is a 1972 911T with a ST body xender discord omegle , the engine is a stock engine but I will like to converted to an ST spec.
Trackrash 12-31-2019 05:24 PM
ADMIN, Have you seen this post? ^
