can you suggest a degreaser safe for magnesium ?
Looking for something to use on my 2.2T rebuild, preferably something I don't need to babysit. I don't want to worry about leaving it on the case too long and ruining it. What do you guys use?
Old 09-28-2017, 05:02 AM
I'm doing a 2.2 right now.
I soak it in safety kleen, dry it, power wash it then spray it with sams club degreaser, let it set for a few minutes and power wash it again.
Magnesium is naturally dark.
After building, there is a spray can of sealant that comes from a boat store that sprayed on and seals the magnesium surface.
Bruce
Old 09-28-2017, 08:14 AM
Hi Bruce,
Actually, Mg is a shiny silvery metal in its natural state.
Since it has two valance electrons, its highly reactive and bonds with oxygen to oxidize and its the magnesium oxide that gives it its dark color after being exposed to air.
This is why it needs to always be coated to prevent terminal corrosion.
Steve Weiner
Rennsport Systems
Portland Oregon
(503) 244-0990
porsche@rennsportsystems.com
www.rennsportsystems.com
Old 09-28-2017, 09:00 AM
I don't even bother with degreasing anymore. I run the case halves over to the machine shop, have them hot tank it (50 bucks) and then have them soda blast it (150). It comes out looking like virgin metal.
For mag, you can then spray the outside with clearcoat or whatever to protect it.
This process alone has saved me tons of time with case cleaning. No more toothbrushes, no more hours spent fiddling and cleaning crevices. Get the case soda blasted and start building it the moment it comes back.
Old 09-28-2017, 09:43 AM
Catorce
Who would provide the service you get from your machine shop and the soda blast as a business
Say in Chicago.....
Would like to find this type of service
Frank
Gold71
Old 09-28-2017, 11:11 AM
Originally Posted by 82 sportsc View Post
Catorce
Say in Chicago.....
Frank
Far as I know any automotive machine shop does this in house. They use Soda because it doesn't matter if it all washes out or not - it is inert and dissolves eventually so totally safe for motors.
Old 09-28-2017, 03:46 PM
Simple green
Old 09-28-2017, 09:22 PM
Originally Posted by vmn007 View Post
Simple green
Careful with that stuff as well as other cleaners with advisory labels regarding aluminum. Long soak periods may affect the appearance of the material.
Sherwood
Old 09-29-2017, 12:14 AM
Puny Bird
Mark Henry's Avatar
LA totally awesome, if you want to put it in long term dilute it. I run about 2:1 one part water. You have to wash it with soap and water when done. It will get it clean enough to use, but it won't give you a shiny case.
Super cheap.
'74 Porsche 914, 3.0/6
'72 Porsche 914, 1.7, wife's summer DD
'67 Bug, 2600cc T4,'67 Bus, 2.0 T1
Not putting miles on your car is like not having sex with your girlfriend, so she'll be more desirable to her next boyfriend.
Old 09-30-2017, 12:28 PM
Reiver
Reiver's Avatar
Sherwood
There is a simple green for aviation use that is alloy safe.
De Oppresso Liber
Strength and Honor 5th Legion
Old 09-30-2017, 08:44 PM
Ctopher's Avatar
Yep that is all I use now....safe for most all types of metals. And you can find it in gallon jugs on Amazon.
Simple Green Extreme Aircraft Precision Cleaner | Industrial
Old 10-04-2017, 08:20 PM
Originally Posted by Steve@Rennsport View Post
Hi Bruce,
What would be a good coating product on a freshly cleaned magnesium engine case?
Thanks,
Bert Jayasekera
1970 911T - Tangerine Orange
Early 911S Registry #494
R Gruppe #167
Old 10-05-2017, 01:28 PM
I am a regular spray degreaser user that I bought from Rx marine
RX Marine was established in 1996 in Mumbai, India; as chemical manufacturing company catering exclusively to the needs of the marine industry. In a short span of 12 years the company has established itself as one of the leading wholesale suppliers of a wide range of chemicals for - Marine industry internationally - and other local industires and plants. Our client list bears testimony to this. The RXSOL policy has its foundations on two pillars of strength - a continuous investment in research and development to deliver premium quality products and a commitment to service.
Degreaser
Old 01-05-2020, 04:46 AM
For a clear coat there is nothing better than Cerakote, if you don,t want to mask and spray use Gibbs oil
Old 01-05-2020, 06:33 AM
anything oil based. Not water based. If so avoid acidic
80SC (ex California)
Old 01-05-2020, 11:35 AM
Slippery Slope Expert
Steam Driver's Avatar
When I had BMW airhead bikes I had good luck with uncoated mag wheel cleaner (mold phosphoric acid, I think) followed by Simple Green.
“As new technologies become indistinguishable from magic, and I can no longer tinker, the magic goes away for me.”
Old 01-05-2020, 01:47 PM
