-   -   Nut in left timing chain housing (http://forums.pelicanparts.com/911-engine-rebuilding-forum/1049064-nut-left-timing-chain-housing.html)
tlholliday 01-04-2020 04:19 PM
Does anyone know if the nut in the left case timing chain housing needs a washer with it? I am about to put the two cases together and Wayne's book doesn't mentioned a washer but just the nut.
Flat6pac 01-04-2020 04:41 PM
The 10 mm nut requires a washer, basically, all nuts require washers.
On 77 and earlier the thread is 10x1.75 like the through bolts
On 78 and later the thread is 10x1.0.like the through bolts
Bruce
tlholliday 01-04-2020 05:16 PM
Richey 01-04-2020 05:22 PM
A wavey lock washer to be exact .
