donbecker1234's Avatar
93010090104 gasket kit content / parts list?
Wrightwood Gasket Set
Does anyone have a list handy of what parts are included in this set?
Thanks!
Old 04-15-2020, 08:38 AM
If you lookup the part number 930 100 901 04 in the PET. You will get a list of parts that should be in the kit.
Old 04-17-2020, 06:55 PM
Oh great point thanks
Old 04-17-2020, 07:10 PM
I was able to look up all of them except for "90110219100". It appears in the PET kit list, but not anywhere else that I could find.
Sealing Ring (x3) [Engine Oil Cooler Small Orings] 99970417250
Oring (x26) [Engine Case Halves Orings] 99970100640
Sealing Ring 90x110x12 (x1) [Crankshaft Flywheel Seal] 99911321540
Gasket (x2) [Engine Sump Plate Gasket] 93010139101
Sealing Ring A 22x27 (x1) [Oil Drain Plug Aluminum Washer] 90012311830
Oil Scraper Ring 30x50x10 (x1) [Crankshaft Pulley Seal] 99911304950
Oring 51x4.5 (x1) [Crankshaft Main Bearing Oring] 99970728540
Sealing Ring A 18x22 (x1) [Turbo Oil Reservoir Aluminum Sealing Washer] 90012304430
Sealing Ring A 10x16 (x8) [Crankcase Sealing Ring] 90012306630
Washer 6.4 (x3) [Chain Housing Cover Washer] 90003101130
Sealing Ring A 12x16 (x4) [Plug to Cam tower copper sealing washer] 90012300500
Washer 8.4 (x24) [Valve Cover Washer] 90003101430
Gasket (x1) [Intermediate Shaft Cover Plate Gasket] 93010519801
Sealing Ring (x1) [Engine Oil Cooler Large Oring] 99970417350
Sealing Ring A 22x27 (x1) [Oil Crossover Line Union Aluminum Sealing Washer] 90012301130
Sealing Ring 39.2x3 (x1) [Engine Oil Thermostat Oring] 99970105350
Sealing Ring A 18x24 (x2) [Engine Piston/Spring Pressure? Aluminum Sealing Washer] 90012310630
Gasket (x1) [Breather Cover Gasket] 93010779102
Sealing Ring (x1) [Distributor Oring] 91160210201
Sealing Ring A 18x24 (x1) [Oil Pressure Transmitter Copper sealing washer] 90012300920
Sealing Ring A 14x18 (x2) [Engine Rear Temp Switch Aluminum Sealing Washer] 90012300730
Sealing Ring (x1) [???] 90110219100
Round Seal 33.3 x 2.4 (x1) [Intermediate Shaft Cover Plate Oring] 99970165840
Old 04-27-2020, 12:37 PM
