-   -   opinions on this engine local to me? (http://forums.pelicanparts.com/911-engine-rebuilding-forum/1050197-opinions-engine-local-me.html)
jmitro 01-17-2020 04:58 AM
this popped up on my local facebook. I've considered buying it for future rebuild and install into my flared 74 914. Appears to be a 911T engine.
https://www.facebook.com/marketplace/item/2674783612589753/
value as a core?
how easy/expensive would it be to rebuild as E or S specs?
sorry for the newb questions. Not that familiar with 911 six engines
targa72e 01-17-2020 01:14 PM
70 T engine so no oil squirters for pistons. Mag case so if it needs the works figure on 15K if you build it your self. I listed some pricing for my 2.4 build in this post, also good price estimates from others.
http://forums.pelicanparts.com/911-engine-rebuilding-forum/1048182-2-4-engine-st-speces.html
john
Trackrash 01-20-2020 01:09 PM
Without a running history, it might be worth half what is being asked just in parts.
I would do a leakdown and bore scope inspection, at the very least, if I was interested in this motor.
If you are not experienced with these motors, and expect someone else to do the wrenching, you will probably be in for a big surprise.
jmitro 01-20-2020 01:31 PM
Thanks for the input. I decided to pass on it for now.
I’m learning about the costs of 6 cyl engines
Flat6pac 01-20-2020 07:15 PM
Better off to start with a 3.0
Residual value is higher and build costs tend to be less
Hate to see anyone with $15000+ in a 2.2
Bruce
Matt Monson 01-21-2020 11:34 AM
Bruce
3l offers all kinds of clutch and gearbox strength issues on a 914. Better to stick with the 2.2-2.7l engines for a -6 conversion unless one is also doing a 915/916 gearbox conversion at the same time.
