Oh no, another cam recommendation thread!: street-driven mild 3.6 EFI/ITB
I've skimmed through a bevy of threads and there's a lot out there around 2.7-3.4 motors, but not as much around 3.6s that I could find. Rebuilding a '92 3.6 into a mild hot rod motor with stock P/C, leaving heads alone, but with ITBs/EFI. Planning to modify factory manifolds into a GT3 style plenum with Jenveys, similar to the Rothsport setup. Car will only see 2-3 DE track days a year, so 95% street driven. Wide power band and good low-mid range torque is paramount.
Anybody have experience/thoughts/recommendations? 20/21? DC21? 993SS? Thanks! -Mike |
My 964 engine was rebuilt to stock specs however it has stock induction and plenum, but has 993ss cams, rothsport headers, and tune to support it. The car pulls very nice.
I suspect you’ll get some gain from the induction but to make real power head work is needed. |
You might look over at the 964 forum on rennlist, lots of 3.6 and larger builds their. By keeping stock P&C you are limiting cam selection to stock type cams. These work best with stock type intake. To take advantage of ITB you need different pistons to support more aggressive cams. This also requires upgraded rods to take advantage of more RPM that your cams and intake support.
john |
just a data point. 993SS cams, otherwise stock internals, stock plastic intake, B&B headers, 997 muffler, Steve Wong chip on Motronic.
267 to wheels on the dyno. I expect you will get more with ITBs since the system is intake limited. However, you can't really add more rpm and cam without work on the bottom end to support. My $0.02. |
I modified a 92 964 3.6L with Rasant Product ITBs and GT3 plenum but left the internals stock. Switched to MoTec engine management. BBE exhaust with equal length headers and kept heat. End result is slightly over 300RWHP with 260 ft lbs torque. The car is tons of fun to drive. It is a responsibly upgraded engine that makes for a great street car.
Here is a link: www.rasantproducts.com http://forums.pelicanparts.com/uploa...1579339082.jpg |
Andrew at Rasant is great to deal with. I bought my MoTec M130 ECU, custom wiring harness, fuel injectors, WeaponX coil on plug ignition system, and pulley for my new race engine from William Knight who sourced them from Rasant.
P.S. Are you sure that is not crank horsepower? 300 RWHP with a G50 is about 350 HP at the crank. You can't get there with stock '92 internals. |
With ITB’syou can get pretty aggressive with overlap. DC21 is a great safe choice! Slightly more aggressive than SS/RS cams. In your shoes I’d do the DC24’s though. Much better match for ITB’s & GT3 intake. Those would wind out REALLY nice!
300whp on stock internals LOL
american horsepower strikes again |
http://forums.pelicanparts.com/uploa...1579419606.jpg |
I don't know what to tell you. All I know is there is no way a stock long block '92 964 engine is going to have 350HP at the crank just by changing ECU, headers, and intake.
I am sure those numbers are correct for that dyno. But that doesn't mean those match real world numbers. It will be interesting to see what my race engine dynos at when Andrew tunes it on that same type of dyno....maybe even the exact same dyno. |
Well, there is something else to consider. The Dynapack with a Transmission Correction Factor (TCF) of 1.000 (no correction) will be somewhere in between a roller chassis dyno and an engine flywheel dyno.
Another point to consider is what transmission was used and what the actual gear ratio and final drive ratio was used as the Dynapack measures torque at the wheel which must be reduced based on the gear ratio and final drive ratio. HP is calculated from that torque so getting proper torque and HP numbers can only happen if the ratio listed on the chart is correct. Regardless, let's say the TCF should be 1.09. That is still 328 HP at the crank. That is 81 HP over the claimed stock 247 HP at the crank. Still not really possible..... |
https://www.youtube.com/watch?v=2cmpmZmUPtE |
I'm at 282 whp, stock internals except cams and a slight porting. Also stock intake minus the vane airflow sensor.
The torque number is reasonable for flywheel, a bit high for rear wheel. Maybe that dyno is already corrected for drivetrain loss.
Sent from my Nokia 7.1 using Tapatalk |
Thanks all for your insightful input. A quick update, my cylinders are with EBS for replating and honing. I've also decided to opt for a set of new CP pistons in 11:5:1 CR which will open up cam choice a bit. My goal is still to keep this motor rather mild to help elongate the life span of my 915 so cams will land somewhere in the DC24 range.
11.5 ? thats a lot is it not ? How will you avoid detonation ?
Maybe you missed the point. The point is that your 11.5:1 engine has a lot more compression than a standard 3.6 as delivered. So, if you are running pump gas, it would be good if your EFI system has knock sensors and can retard the timing.
My race engine with about the same compression ratio and probably 25 degrees of advance needs 100 octane race gas to be safe. So be careful!
I'm building this exact same setup and I'm hoping for 270 WHP. That would be a nice 90hp jump over my RoW 3.0 that dyno'd at 180 whp. I was recommended and went with 95 3.6 with Rasant ITB's/ GT3 Plenum DC 21 cams and AEM Stand Alone.
| All times are GMT -8. The time now is 09:54 PM. |
