-   -   Which O2 Sensor should I install? (http://forums.pelicanparts.com/911-engine-rebuilding-forum/105022-o2-sensor-should-i-install.html)
WERK I 04-03-2003 03:12 PM
I'm in the process of rebuilding my 85 930 engine. While I'm at it, there will be a new set of B&B headers installed as part of the upgrade. Since there is no emission control system on the 85's, I was wondering which sensor would provide me with the most tuning benefit. I'm looking for something that will interface with the sensor and provide a very accurate A/F ratio at various states of engine load. As a little bit of insurance, an Andial Fuel enrichment circuit is being installed.
TIA
Dave
85 Factory Slant 930
ChrisBennet 04-03-2003 03:32 PM
A "normal" O2 sensor isn't really usable for tuning. You need a wide band O2 sensor. Until recently, these were very expensive. Check out the wide band O2 sensor from Tech Edge. This was device was developed by people on the DIY-EFI list.
-Chris
Wayne 962 04-03-2003 03:41 PM
"Since there is no emission control system on the 85's," - not true.
I don't completely understand your question? Emissions control system includes catalytic converters. Did you mean "mixture control?"
There's a neat K&N kit out there with a built-in gauge to use for tuning. I'm not sure of it's accuracy range though...
-Wayne
WERK I 04-03-2003 03:43 PM
Hi there, neighbor!!
Thanks Chris, I'll check it out.
Dave
WERK I 04-03-2003 03:51 PM
Wayne,
This is a MY 1985 RoW 930 motor. All it had (and I emphasize "had") were the air injection hardware. No cats, no lambda, no DME.
Dave
ChrisBennet 04-03-2003 03:56 PM
Dave
When are you going to invite me down to see your motor? :D
-Chris
WERK I 04-03-2003 04:25 PM
You would find it difficult to find anything that resembles a complete engine, at this time....:cool:
Davehttp://forums.pelicanparts.com/uploads/dk_930pieces.jpg
911pcars 04-03-2003 08:51 PM
I notice the NTK wide band sensors have 5 wires. Can these be used with a regular 3 or 4-wire type O2 sensor guage? Or... does anyone make a wide-band 4-wire sensor?
Sherwood Lee
http://members.rennlist.org/911pcars
Wayne 962 04-03-2003 11:00 PM
Cool, Row did not have much in emissions...
There's an article in our tech section about building an in-dash air-fuel monitor...
-Wayne
