-   -   Gap between newly installed engine and new tin gasket (http://forums.pelicanparts.com/911-engine-rebuilding-forum/1051524-gap-between-newly-installed-engine-new-tin-gasket.html)
bigred23 02-02-2020 05:57 PM
I just finished installing my rebuilt engine in my 1982 SC. While the engine was out, I installed new engine compartment tin gaskets. After getting the engine installed, there’s about a 1” gap between the engine tins and gasket. The long side of the gasket has 2 flaps - does one go above and one below the tins? I can work some of the gasket to do that, but it just pops upward. Suggestions?
bigred23 02-02-2020 07:02 PM
here's a picturehttp://forums.pelicanparts.com/uploa...1580698872.jpg
Tyson Schmidt 02-02-2020 10:43 PM
Yes,you have to pull the lower flap down all around the perimeter.
You can sometimes do it with you fingers and may need to use a tool to help if it’s a tight fit.
