-   -   New cast iron cylinders for 2.7 rebuild? (http://forums.pelicanparts.com/911-engine-rebuilding-forum/1052116-new-cast-iron-cylinders-2-7-rebuild.html)
Nux 02-09-2020 05:49 AM
I'm rebuilding a 2.7.
Bad leakdown and excessive oil consumption.
Turns out, it has badly worn alusil cylinders.
So I've looked for replacements and found a package from Design911 (England) consisting of 90mm cast iron cylinders with JE pistons 9.5cr. No CE gasket on top of cylinders.
What is your opinion on that? Price is very good indeed, about 2500$ for at p/c set. They also do a slip-fit 92mm for a 2.8 big bore. Same price.
lvporschepilot 02-09-2020 06:45 AM
The cast iron cylinders work fine but IMO a CE ring groove should be machined. Measure everything of course.
Anglocanadian 02-09-2020 07:00 AM
It sounds like they are QSC cylinders which come without CE ring grooves.
I'm currently using the same 90mm,s for my 2.5 , I'm lucky in having the use of a lathe and was able to add them. I actually contacted QSC for there opinion on this and did not get a reply.
r lane 02-09-2020 10:55 AM
You can have them Nikasiled.
r lane 02-09-2020 10:59 AM
Think before writing. I am not sure whether the pistons for Alusil are compatible with Nikasil cylinders, and I may have this issue confused with mixing KS with Mahle. Sorry for the runaround. Bob
Nux 02-09-2020 11:23 AM
Haha - well I didn't really think about that. Might actually be a viable option with new JE pistons.
But then again, with the other option we can go 2.8 for the same price.
Nux 02-09-2020 11:30 AM
You're probably right. They're called 'retro performance' at Design911.
I was wrong about the price, it's only 2000$ for a complete set.
Anglocanadian 02-09-2020 12:12 PM
My thinking was I will only be using the car for cruising on sunny days so why go to the expense of building a competition engine !
targa72e 02-09-2020 12:45 PM
Why not sent your Alusil cylinders out to be coated with Nickasil. You would need new pistons from JE or CP but you could pick what you want. Nickasil will wear better than cast iron and Aluminum has better cooling. EBS does these on an exchange basis.
john
Trackrash 02-09-2020 01:27 PM
john
And while you are at it have them bored to 92. Might be worth the extra $$.
Nux 02-10-2020 01:36 PM
john
Thats my current plan. Cost is about the same, but I get nikasil and a CE gasket. Win-win.
Add JE 9.5cr pistons and this should be a happy little engine again.
