-   -   Strange CIS banjo fitting (http://forums.pelicanparts.com/911-engine-rebuilding-forum/1052346-strange-cis-banjo-fitting.html)
gorskined 02-11-2020 08:32 AM
working on my cis system out of a 3.0l 76 row turbo .. i removed all the banjo fitting a week ago to soak and clean them .. while i was inspecting the parts last night i noticed two of the banjo fittings were different than the rest. They look to have plastic restrictors in them and i have no idea where they go .. any help would be greatly appreciated
Regards Nedhttp://forums.pelicanparts.com/uploa...1581438617.jpg
http://forums.pelicanparts.com/uploa...1581438713.jpg
http://forums.pelicanparts.com/uploa...1581438743.jpg
Flat6pac 02-11-2020 09:57 AM
They are check valve banjos they probably go to the fuel distributor area.
But then I don’t remember them from my 76 turbo
Bruce
dannobee 02-11-2020 11:41 AM
Look closely and see if they're not screens instead of check valves.
gorskined 02-11-2020 12:24 PM
No screens just a little plastic plug that rattles back and forth . when you shake it. i don't see how these can work as a check valve there is no spring behind them .
mepstein 02-11-2020 01:02 PM
Ask Boy911SC / Tony
