Help can't install this cis spring loaded.
Ok so how do I load this spring and install it?? Spent the last 2 hours ..I'm stumped.. any help would greatly be appreciated...regards Nedhttp://forums.pelicanparts.com/uploa...1581972356.jpg
Air Flow Meter (AFM).......
What model year this AFM unit came from? Was this taken off from a 911 CIS? Looking for something similar to your AFM to check. Thanks.
Tony |
After another hour or so I devise the way to install the spring on the bench.. by using a cut 5/16 drill bit . Then placing in the arm and pushing the bit shaft our using the original shaft
Worked really well....shafthttp://forums.pelicanparts.com/uploa...1582042023.jpg http://forums.pelicanparts.com/uploa...1582042059.jpg http://forums.pelicanparts.com/uploa...1582042101.jpg |
| All times are GMT -8. The time now is 02:11 AM. |
