-   -   3.0 crank in a 2.7 (http://forums.pelicanparts.com/911-engine-rebuilding-forum/105294-3-0-crank-2-7-a.html)
Joe Davis 04-05-2003 07:12 PM
3.0 crank in a 2.7
Other than having to bore the cases can anyone comment on using a later 3.0 crankshaft in a 2.7 cases
Any advantages?
Big problems
joe
Wayne 962 04-06-2003 04:46 PM
I can't see *any* advantage to it. The 2.7 crank is the same as the 3.0 crank, except for the flywheel end...
-Wayne
