Sealing Turbo Heads ?
When assembling the 3.3L turbo head (no gasket), it it done dry or do you use the loctite 574 ?
Thanks, Dave |
Dry
The head to cam tower interface uses the Loctite 574...
-Wayne |
-Chris |
Thanks Guys. Yes, I was referring to the head to cylinder interface.
Dave |
How does this metal-to-metal, no-gasket head sealing method work out in the long run? I'd think some sort of copper o-ring and groove system would provide a more positive seal. No issues here?
Sherwood Lee http://members.rennlist.org/911pcars |
A stock 930 rebuild uses no sealing gasket between the cylinder and head. When building a higher performance 930,sometimes the cylinder and the head is machined to recieve a nirosist ring. Its almost an interference fit between the nirosist ring, the cylinder and the head. This helps keep the cylinder sealed when pushing higher than stock boost.
The aluminum is soft - so it sortof acts as it's own gasket. It's common not to run a gasket on the VW air cooled engines...
-Wayne |
It's interesting that my '77 930 engine (3.0) DOES use a CE-style sealing gasket between cylinder and head. I guess when the factory went to 3.3 they decided it was unnecessary.
Colin |
Did the same when they moved from 3.0L to 3.2
| All times are GMT -8. The time now is 01:28 AM. |
