Tired of crispy wires
I got so tired of messing with crispy, nasty old engine harnesses that we decided to make our own. Now we can offer them to all of you.
http://forums.pelicanparts.com/uploa...1582062443.jpg http://forums.pelicanparts.com/uploa...1582062745.jpg http://forums.pelicanparts.com/uploa...1582062795.jpg http://forums.pelicanparts.com/uploa...1582062614.JPG http://forums.pelicanparts.com/uploa...1582062614.JPG |
Stupid question: how difficult is it to replace the engine wiring harness with the engine in the car? I'm going to drop mine but it'll be a while.
http://forums.pelicanparts.com/uploa...1582079154.jpg |
Thanks. I’ll hold off until I have the engine out.
Thanks Henry,
I’ll trade you 4 of them for one of your sweet looking 3.1 cylinder kits. :) |
I see a sweet MFI harness from Henry and a sweet CIS harness from Timmy. Do either of you make a harness for a 3.0 CIS going to PMO carbs?
I choose to use a double sender of pressure and idiot light that mounts on top of the engine to get a more accurate pressure reading. It also cleans up the wiring near the alternator housing. The temp wire runs under the fan rather than over the top. We can add the ignition/distributor wires but I prefer a stand alone harness for that. It allows for more ignition options. If you still have an external regulator we can add those wires as well. |
I use FR Wrap. This picture is of one without the CDI wiring. Lots of different harnesses I’ve built posted over 32 pages here: http://forums.pelicanparts.com/porsche-911-used-parts-sale-wanted/740894-building-sc-mid-year-engine-harnesses-32.html http://forums.pelicanparts.com/uploa...1582602479.jpg |
3.0 carb or EFI with ignition....
Just made one this weekend actually, in the mail tomorrow. The harness on the right is for a 3.0 carb engine with MSD with an adapter and extra wiring to make it plug and play with the MSD. The others in the photo are for brakes, fuel pump and front lighting harnesses for a stripped down hotrod. http://forums.pelicanparts.com/uploa...1582606742.jpg |
| All times are GMT -8. The time now is 07:27 PM. |
