-   -   Cam Pitting, Piston Oil Squirter Testing Without Splitting Case (http://forums.pelicanparts.com/911-engine-rebuilding-forum/1054027-cam-pitting-piston-oil-squirter-testing-without-splitting-case.html)
Henry Schmidt 02-05-2021 09:43 AM
Originally Posted by Martinlassmann (Post 11211289)
4mm with an early 4 rip pump or 964?
Pump makes no difference.
burgermeister 02-05-2021 10:41 AM
What my rockers looked like. This is <15,000 miles of driving using BP20W50 oil.
http://forums.pelicanparts.com/uploa...1612550342.JPG
ahh911 02-05-2021 11:05 AM
Meister,
Are these the one's you had reworked? If so, how are they doing?
Phil
burgermeister 02-05-2021 01:42 PM
Yep, John reground that set. I have not checked it over in detail, but I do peek at whatever cam lobes are visible at the annual valve adjustment, and I have not found anything. Mileage on the set is probably 20-25K. A decent amount of track use initially, though only a 2 day weekend in the last 2 years.
Harpo 02-07-2021 03:09 PM
Thanks Henry, good to know, thanks for sharing!
Originally Posted by Henry Schmidt (Post 11209864)
In my opinion the factory oil cam feed restrictor is too small.
From memory... 2.5mm. The non-restricted fitting is 6mm.
We modify the opening to 4mm. This gives us the best of both worlds.
