-   -   Oil Pump(930) torque specs, etc.? (http://forums.pelicanparts.com/911-engine-rebuilding-forum/105415-oil-pump-930-torque-specs-etc.html)
WERK I 04-07-2003 06:22 AM
I just visited the machine shop that was cleaning various engine parts. In his thorough cleaning regimen, he disassembled the oil pump. Well, this is something I really did not want him to do, but that is water under the bridge... I have a few of questions;
Q: Is only one of the shafts keyed and is it the main shaft gears?
Q: Are there any ramifications that we should be aware of before reassembly occurs because the pump was disassembled?
Q: What are the torque specs for the housing assembly?
Q: Are the housings assembled dry(no sealer or gasket)?
Thanks in advance,
Dave
