-   -   Piston ring gaps (http://forums.pelicanparts.com/911-engine-rebuilding-forum/1054298-piston-ring-gaps.html)
ajwans 03-05-2020 03:22 PM
Piston ring gaps
Can anybody give me some guidance on what to set the piston ring gap for 2.0S rings? Everything is Mahle if that makes a difference.
The factory workshop manual shows the ring gap to be 0.15mm (0.006") which seems a little small, not that I know more than the factory, only everywhere else I look they give a rule of thumb like 0.004" per inch.
http://forums.pelicanparts.com/uploa...1583450472.png
What gives? Do we run super close rings on early cars or did the factory have a misprint in their specs?
andy
Trackrash 03-05-2020 07:39 PM
The spec is 0.006 to 0.0177". So 0.006" is the minimum allowed.
r lane 03-08-2020 11:59 AM
I might ere on the loose side. An extra .01, .02 will have 0 effect on the compression. Too tight and they touch, the ring begins to twist or buckle and lose contact.
dannobee 03-08-2020 12:49 PM
If the ring gap is too small it can pull the top of the piston right off. No, I'm not joking.
manbridge 74 03-08-2020 02:19 PM
Looks like your using factory parts and using factory specs won’t give you any issues. The spec is not a misprint, the cylinders really do expand on these.
VFR750 03-12-2020 03:41 PM
That spec is correct for air cooled cylinders.
.004/1” bore is for water cooled engines.
I did 0.008” gap on all. Just fine
ajwans 03-12-2020 03:51 PM
Thank you. That was the part I was missing in all of this. Our cylinders expand way more than US domestic iron/steel bores.
All makes sense now, thanks all for your comments.
andy
