Thumbs up Looking for contacts with 3.2l SS and 46mm Carbs
Hey everyone,
I am currently building up a 3.2l Short Stroke engine with TwinPlug and 46mm Weber carburetors. Currently, we are starting to setup the engine (carburetors, ignition map...).
I am looking for persons with a similar setup to discuss some details. Caused by the situation here with COVID, all toolshops and test-benches are closed atm.
Highly appreciate any feedback or hints.
All the best,
Max
Old 03-28-2020, 05:24 AM
I have that, what kind of things are you interested in knowing.
What kind of compression and cams do you have.
1976 914
1986 951
Old 03-28-2020, 02:41 PM
Compression
Hey Colin,
Here my camshafts:
Compression should be fairly standard around 9,6. I have the MaxMoritz pistons. I am urgently looking for an ignition-map to start from. Can you help?
Best greetings from Munich,
Max
Old 04-01-2020, 03:20 PM
are you running a distributor or a mappable ignition that is electronic.
1976 914
1986 951
Old 04-01-2020, 03:26 PM
If you're running twin plugs yet still under 10:1 compression, I would set timing as follows as a baseline setting:
1000-1200rpm 5 -7 degrees (idle)
2500-3000rpm 20 degrees
4000rpm 27-28 degrees
With compression being not quite so high you will probably be able to bring in a couple more degrees timing at various places, but this should get you going.
No physical quantity completely explains its own existence
Old 04-01-2020, 05:57 PM
Mapping
Hey guys,
Thanks for the quick answers and the first indications
I am running a mappable ignition. We use the Trijekt Bee ECU for ignition. I regarding compression, we might be a little bit above 9,6 - maybe 9,8.
Best,
Max
Old 04-01-2020, 10:56 PM
Originally Posted by SirMaeXchen View Post
Hey guys,
Best,
Max
The estimations I made are based on wide open throttle above 2500rpm. Partial throttle timing can be 5-9 degrees more depending on volumetric efficiency. Each engine will be different.
Old 04-02-2020, 06:15 PM
