Hey everyone,
I am currently building up a 3.2l Short Stroke engine with TwinPlug and 46mm Weber carburetors. Currently, we are starting to setup the engine (carburetors, ignition map...). I am looking for persons with a similar setup to discuss some details. Caused by the situation here with COVID, all toolshops and test-benches are closed atm. Highly appreciate any feedback or hints. All the best, Max |
I have that, what kind of things are you interested in knowing.
What kind of compression and cams do you have.
1976 911 1976 914 1986 951 |
Compression
Hey Colin,
Here my camshafts: ![]() Compression should be fairly standard around 9,6. I have the MaxMoritz pistons. I am urgently looking for an ignition-map to start from. Can you help? Best greetings from Munich, Max |
are you running a distributor or a mappable ignition that is electronic.
If you're running twin plugs yet still under 10:1 compression, I would set timing as follows as a baseline setting:
1000-1200rpm 5 -7 degrees (idle) 2500-3000rpm 20 degrees 4000rpm 27-28 degrees With compression being not quite so high you will probably be able to bring in a couple more degrees timing at various places, but this should get you going.
No physical quantity completely explains its own existence |
Mapping
Hey guys,
Thanks for the quick answers and the first indications ![]() I am running a mappable ignition. We use the Trijekt Bee ECU for ignition. I regarding compression, we might be a little bit above 9,6 - maybe 9,8. Best, Max |
The estimations I made are based on wide open throttle above 2500rpm. Partial throttle timing can be 5-9 degrees more depending on volumetric efficiency. Each engine will be different.
