911s pistons?
My 67S engine is pulled apart.
Where. Do I find a part number on the pistons confirming.they are the real deal. ??? I already think the cams are not S Lyndon |
There is casting numbers inside the piston with manufacture name if original equipment
There is a reference list on here but I looked a little and didn’t see it I have a printed version in garage. Bruce |
Post a pic do they have crazy domes ?
some 2.0L casting numbers
2.0 65-67 80mm Mahle 80v37 2.0 E 69 80mm Mahle 80v79 2.0 S 67-68 80mm Mahle 80P26 2.0 S 69 80mm Mahle 2.0 906 80mm Mahle 10.3 80P26 john |
![]() ![]() ![]() Ok the pistons. ??? I will clean them later. Now it looks like I don't have S Cams??? Should I get them or is what I have ok. Its a 901 /02 engine I will check that I S heads. I think they are correct because they are all 9/ 66 |
![]() Ok 79.95 100 Sp0.05 Made in Germany |
It's a 914 ...
Look on the underside of the crown for the numbers targe72e mentions
80226E I think
![]() Jackpot. 80P26 is a 67 S piston. So I will chase a set of rings up. So are my cams ok or should I chase a STD set. Lyndon |
You should see the 69S domes...
Bruce |
Ok looks like I need oversize pistons 😦 .5 mm any thoughts or advice be appreciated.
One thought can they be coated and then use my original pistons ? Lyndon |
the cam part number is for a T cam, low performance unless they have been welded up and reground. They will have plenty of clearance with S pistons but you would make better power with more aggressive cams.
john |
Under the radar
What number is stamped on the end of the cam? Does the left cam have a MFI drive?
![]() 03 on the end of one cam. So the. T cams arnt much good. Is an E cam better |
Under the radar
E or Solex cams would be a good street cam. You probably could get those T cams reground to E or Solex specs. S cams are cool, but your motor will be a dog below 5000 rpm. I guess there is a chance the cams you have were reground. I'm not sure what the best way to check would be.
