911s pistons?
My 67S engine is pulled apart.
Where. Do I find a part number on the pistons confirming.they are the real deal. ???
I already think the cams are not S
Lyndon
Old 04-07-2020, 05:39 AM
There is casting numbers inside the piston with manufacture name if original equipment
There is a reference list on here but I looked a little and didn’t see it
I have a printed version in garage.
Bruce
Old 04-07-2020, 11:11 AM
Post a pic do they have crazy domes ?
Old 04-07-2020, 12:44 PM
targa72e's Avatar
some 2.0L casting numbers
2.0 65-67 80mm Mahle 80v37
2.0 E 69 80mm Mahle 80v79
2.0 S 67-68 80mm Mahle 80P26
2.0 S 69 80mm Mahle
2.0 906 80mm Mahle 10.3 80P26
john
Old 04-07-2020, 01:41 PM
Ok the pistons. ??? I will clean them later.
Now it looks like I don't have S Cams???
Should I get them or is what I have ok.
Its a 901 /02 engine
I will check that I S heads. I think they are correct because they are all 9/ 66
Old 04-07-2020, 04:41 PM
Ok
79.95
100
Sp0.05
Made in Germany
Old 04-07-2020, 05:07 PM
It's a 914 ...
stownsen914's Avatar
Look on the underside of the crown for the numbers targe72e mentions
Old 04-07-2020, 08:31 PM
80226E I think
Old 04-07-2020, 08:40 PM
Jackpot.
80P26 is a 67 S piston.
So I will chase a set of rings up.
So are my cams ok or should I chase a STD set.
Lyndon
Old 04-07-2020, 09:12 PM
You should see the 69S domes...
Bruce
Old 04-08-2020, 09:22 AM
Ok looks like I need oversize pistons 😦 .5 mm any thoughts or advice be appreciated.
One thought can they be coated and then use my original pistons ?
Lyndon
Old 04-08-2020, 06:23 PM
targa72e's Avatar
the cam part number is for a T cam, low performance unless they have been welded up and reground. They will have plenty of clearance with S pistons but you would make better power with more aggressive cams.
john
Old 04-09-2020, 12:58 PM
Under the radar
Trackrash's Avatar
What number is stamped on the end of the cam? Does the left cam have a MFI drive?
Gordon
'71 911 Coupe 3,0L outlawed
Old 04-09-2020, 01:24 PM
03 on the end of one cam.
So the. T cams arnt much good. Is an E cam better
Old 04-09-2020, 04:50 PM
Under the radar
Trackrash's Avatar
E or Solex cams would be a good street cam. You probably could get those T cams reground to E or Solex specs. S cams are cool, but your motor will be a dog below 5000 rpm. I guess there is a chance the cams you have were reground. I'm not sure what the best way to check would be.
Gordon
Old 04-09-2020, 07:17 PM
