-   -   Engine weight? (http://forums.pelicanparts.com/911-engine-rebuilding-forum/105842-engine-weight.html)
ROWSC 04-09-2003 05:41 PM
Engine weight?
Any idea how much a 3.0 CIS engine weighs with exhaust? That is, how many middle aged men will I need to help me carry it to the back of the house?
Thanks,
Rich
jgparker 04-10-2003 05:54 AM
I think it's around 500 lbs. I've carried an SC engine with 2 people, but I would recommend 4 if you can get them.
tholyoak 04-10-2003 07:47 AM
It is a bit less than that, the fully crated one I sold in December was 440lbs without exhaust
Todd
Wayne 962 04-10-2003 02:40 PM
3 reasonably non-whimpy guys should be able to lift it onto a stand...
-Wayne
POVI 04-16-2003 08:53 AM
actually 2 guys can do it ;) .. take engine off back of pickup truck and stick in engine stand !
** Warning ** .. you will have sore back and sholders for 2 days ..
haha
- Joe -
ChrisBennet 04-16-2003 10:01 AM
I've said it before, but I think you guys who lift motors by hand are nuts. Use a tool, you're friggin Home Sapiens for krissakes. Back damage is forever.
-Chris
slater 04-27-2003 01:10 AM
I lifted a 2.7 will all of it's peripheals on a pallet out of a truck and on to the ground with 2 other guys... and one of them was actually pretty whimpy. Just remember to put your hands in a position where your fingers wont be under it when it hits the ground - that can make setting the thing down a pain in the.. well, fingers.
snowman 04-27-2003 10:10 PM
I could lift it alone. once at least. really, maybe or almost maybe. ANyway anyone who is a REAL man could lift 500 lbs of engine.
ROWSC 05-05-2003 10:50 AM
The engine project got put on hold. After two years on the waiting list I got a call from the bodyman. Interestingly enough, the shell of a coupe was easy for four guys to lift onto a trailer.
jonesb930 06-05-2003 11:32 AM
Does anyone know the hole size for each of the different squirters? I would like to identify what is installed in my case. :confused:
1fastredsc 06-05-2003 01:59 PM
439lbs with everything. My dad (220lbs) and myself (175lbs) lifted it at one point. But that was after removing the 60lbs of exhaust and the cis.
