-   -   Sealing engine tin...how important is it? (http://forums.pelicanparts.com/911-engine-rebuilding-forum/1058466-sealing-engine-tin-how-important.html)
donbecker1234 04-19-2020 11:43 AM
I just pulled my 1979 930 motor, and I noticed a few elliptical holes in the engine tin that were not being used, on the drivers' side.
http://forums.pelicanparts.com/uploa...1587321708.JPG
I would guess that these were used for the original smog/emissions stuff that is long gone.
Anyways, I was planning on stripping and repainting my tin anyways...should I seal these unused holes up on the engine tin to ensure controlled airflow?
I'm already planning on replacing the engine compartment / tin seals as well as the orings for anything passing thru the tin.
Trackrash 04-19-2020 02:03 PM
Yeah, and that rear piece has the hole for the air pump, which I guess you are not using.
Back in the day those pieces were readily available at the dealer. I would try to find the correct, no holes, versions. I see some used ones on ebay and I bet it comes up here on the Parts for sale forum from time to time. Pelican may have them new in the parts catalog, but I can't locate it with their "wonderful" search tool.
You could always weld and patch, but for the money, you may as well do it right IMO.
Flat6pac 04-19-2020 03:31 PM
Pressure hose for the wastegate passes through one of the holes
Bruce
donbecker1234 04-19-2020 03:44 PM
Bruce
Hi Bruce,
If I recall, both hoses for the wastegate ran thru the round holes, and both had round orings. The two elliptical holes were not being used.
Engine isn't original to the car so I wouldn't be surprised if this is incorrect.
Trackrash 04-19-2020 04:43 PM
Crap. Sorry, didn't notice 930.....
donbecker1234 04-19-2020 06:19 PM
Gordon, I still have the airpump wheel on the scavenge housing, do I still need to source different pieces?
Trackrash 04-19-2020 08:09 PM
I'm not sure. 930s are above my pay rating.:D
Now that I think about it, that rear piece on my SC did not have a cutout like yours. It just had a bump out on the bottom to clear the pump.
It is not that hard to change that rear piece later, at least it isn't on my NA car .
safe 04-21-2020 04:00 AM
I don't think it's super critical to seal it up completely but why not do it as good as possible if they are out.
I think there are 2 ways to do it. Patching it up really nice and invisible or cutting out a block off plate and tacking it in there so its clearly visible and reversible. I've done the latter.
donbecker1234 04-21-2020 06:39 AM
I have some thin metal to block those extra holes off with that should be pretty easy to make invisible.
