Stranger on the Internet
patkeefe's Avatar
Low Idle Vacuum
The sort-of new 2.7 runs OK (except for the oil leaks).
I have some reground Solex grind cams in the engine. I have low vacuum at idle, no air leaks. Once it gets to 2000 RPM, the vacuum is fine. I am guessing cam overlap? The engine is single plug, 9.6:1 JE pistons, stock 2.7 heads.
TIA
Pat
Patrick E. Keefe
78 SC
Old 04-30-2020, 05:05 PM
Check the static timing and full advance .
Kermit, 73 RS clone,
Just Part of the Team
Chris Leydon ,Louis Baldwin ,Peter Brock ,Riche Clark
Jerry Sherman ,Rob McGlade ,Donnie Deal
Hank Clarkson ,Craig Waldner ,Don Kean ,Leroy Axel Gains
Old 04-30-2020, 06:47 PM
patkeefe's Avatar
EFI. I dialed in the static everywhere from 4-10 BTDC. Full advance doesn't matter at idle.
Patrick E. Keefe
78 SC
Old 04-30-2020, 07:20 PM
