2.0 wont run properly
I've just finished my build. Was a 2.0L S with T cams.
It now has dc30 cams and some higher comp Wiseco pistons.
It now pops constantly thru the carbs and to a lesser extent the exhaust.
I cannot get a stable idle and after a rev does not return to idle in a timely manner. Stays up around 2 to 3 k for a few seconds.
Idle mixture does not do much if anything.
Timing is set. Throttle linkage does not stick.
I did not go thru the carbs. They were Working.
Lyndon
Old 07-27-2020, 06:29 PM
Navin Johnson
TimT's Avatar
Congrats, you now bet to play"re-jet" that carb!
Intake pops...= lean
Exhaust pops.. rich..
You rebuilt an engine, changed operating parameters, and plopped the old carbs on..
Refresh the crabs... and fix the jetting..
'69 911 GT-5
'75 914 GT-3
and others
Old 07-27-2020, 06:37 PM
Ok I have 52 ildle jets ?
Do I go to 55 or 60. Its really bad.
Old 07-27-2020, 07:03 PM
It's a 914 ...
stownsen914's Avatar
Post your carb jetting specs - idles, mains, air correctors, emulsion tubes, venturis, etc. You'll get some opinions.
A wide band O2 setup will help you a lot.
Consider the possibility of air leaks at the carb/manifold as well.
Old 07-28-2020, 04:06 AM
I have 135 mains. 52 idle.
With out pulling them apart again. I'm guessing they are std sixty eight 911 L sportomatic webers.
They are on the sixty seven S engine.
I have some sixty idle jets coming tomorrow.
Lyndon
Old 07-28-2020, 04:16 AM
It's a 914 ...
This is for the motor you've been putting together? High comp pistons, correct? S spec cams and heads? Edit - whoops, saw you answered that above
Old 07-28-2020, 09:16 AM
Try clogged jets or passages or idle screws. What size venturis? Are the 6 intakes balanced via the air adjustment screws?
Old 07-28-2020, 08:14 PM
The carbs were done on the old engine last year. With that it ran ok for a worn engine. But I still didn't have any real control on the idle mixtures.
I have never measured the chokes.
Lyndon
Old 07-28-2020, 09:56 PM
Send a message via Yahoo to rgofast
Idle not returning could be the distributor. Turn the key off and back on again rapidly, when the engine is idling to fast. If the idle speed drops then it’s a weak spring in the distributor. Mine was doing that and Jerry Woods rebuilt the distributor. Runs perfectly now.
1969 911TR lightweight, 1850 lb. 245 HP 2.7 short stroke
1973 1/2 911T S optioned sunroof coupe (in progress)
1998 993 Carrera Cabriolet PSS10 lowered E88 cup wheels
1999 996 Carrera Cabriolet
Old 07-29-2020, 03:27 AM
Is that to force the engine to slow thus returning the springs. It may have week springs as it gets its max advance well before 6000rpm
Lyndon
Old 07-29-2020, 03:38 AM
Yes
Old 07-29-2020, 06:11 AM
I had 4 early 911's that the distributor advance mechanism was frozen.
Old 07-29-2020, 06:55 AM
Initial findings. 60 idle jets in. Air screws out 1 turn and all is well in the shop. Should be fine to get it inspected so I can get rego and drive it.
The idle mixtures still do nothing ? The rest balanced well.
Lyndon
Old 07-29-2020, 10:21 PM
