JoeMag's Avatar
Case center line to Cylinder seating surface dim
What is this dimension for 964/993 case?
Old 01-26-2023, 09:50 AM
The designed width is 115.00mm but they are never the same. As much as 0.5mm difference from side to side to side. When building an engine, you should always check this and deck to same width and make decks parallel to main housing bore. Normal build prep.
Old 01-27-2023, 04:57 PM
