Irrationally exuberant
ChrisBennet's Avatar
Blown up sir! 3.2 rod bearing story
I was out in the garage today and found something from years ago.
The story: I was at driving at Watkins Glen when I heard this "Bang!". I quickly looked down at my instruments and the oil pressure gauge read 5 bar. I limped into the pits and turn off the car. I can't remember for sure don't think it would start after that (it was a long time ago).
I tore down the motor when I got home and found this in the sump:
#5? rod bearing was MIA. I figure I must have been hallucinating/mistaken about seeing 5 bar on the gauge. I mentioned it to an engine builder and he said that the 911 oil pump delivers so much volume that what I saw was real.
I thought this might interest the gang. :-)
'80 911 Nogaro blue Phoenix!
'07 BMW 328i 245K miles!
Old 05-18-2020, 07:07 AM
dezzmo's Avatar
It looks like you now have some "Wall Art" material
EarlyS 1017
RGruppe 663
73 911T 3.2
01 Ducati S4 Monster 00 Ducati 996
Old 05-18-2020, 09:43 AM
It's a 914 ...
stownsen914's Avatar
Years ago my dad had a rod bearing failure (also at WGI) on a '70 911, and reported that the oil pressure increased. Sounds counter-intuitive, but it turned out that an oil passage had become blocked. In 1970 the pressure gauge was at the front of the engine, so a blockage downstream could indeed cause a higher reading where the pressure sender was located. Not sure whether the blockage caused the failure, or was the result of it.
Old 05-19-2020, 04:16 AM
Reading pressure at the pully end should aid in eliminating a possible false reading due to schrapnel blockages that could occur between 8 and 1. No complete fail safe method, but the pully end seems to have an advantage
Old 05-19-2020, 12:42 PM
prschmn's Avatar
That stuffs good on cereal. But what's that round thingie I wonder-not the dime which is
more than this comment is worth.
Mark
www.exotechpower.com
1981 Targa-messed with. 91 C2 supercharged track rat
Radical Prosport-irritates the GT3 guys
40 years of rebuilding services
Old 05-20-2020, 05:45 AM
Mysterious engine part.......
Chris,
What is the mysterious part in your picture? That “thing” could NOT be part of the metallic debris from your motor. Any idea? Thanks.
Let’s play a game to pass the time. I will offer a $ dollar who could identify it. Thanks.
Tony
Old 05-20-2020, 06:46 AM
It might be the retaining cap on the air bleed in the oil pressure fed tensioner.
Old 05-20-2020, 07:28 AM
Strike One........
I don’t think so. Try again. Thanks.
Tony
Old 05-20-2020, 07:41 AM
Need mo better views, but resembles a chain housing cover cup washer for a 3.6. Scaling it against the dime though, it is too small enough I believe, but appears to have a radius to its outer edge.
Old 05-20-2020, 12:19 PM
Mysterious debris......
r lane,
Any other guess? Strike two!
Tony
Old 05-20-2020, 12:27 PM
Beer cap?
Buck
'88 Coupe, '87 Cab,
'88 535i sold, '19 GLC 300 DD
Warren Hall, gone but not forgotten
Old 05-21-2020, 06:14 AM
Nope........
Originally Posted by 88911coupe View Post
Beer cap?
Strike 2 Ball 1 (foul ball). Must have been drinking too much beer.
Tony
Old 05-21-2020, 10:24 AM
I vote for a stray spring retainer from your favorite semi-automatic rifle.
More related, a spring retainer from a VW:
https://www.buggiesunlimited.com/golf-cart/e-z-go-3-8andprime;-accelerator-spring-retainer-(fits-1994-up)/6389
And how did the dime escape the carnage or is that the prize for guessing corectly? :-)
Old 05-23-2020, 05:56 PM
evan9eleven's Avatar
I don’t know what it is, but that schrapnel pile says that the fix will definitely cost more then 10 cents.
1981 911SC restomod "Minerva"
2004 Boxster S
2021 Cayman GTS 4.0 manual "Olive"
2014 Cayenne GTS V8 (wife's lover)
The slope is not slippery; in fact it is entirely frictionless.
Old 05-28-2020, 02:44 PM
Originally Posted by boyt911sc View Post
Chris,
Tony
Hi Tony,
You want me to get a better picture of the "mystery part" ?
Old 05-28-2020, 02:54 PM
That would be great.......
Originally Posted by ChrisBennet View Post
Hi Tony,
Chris,
You had been AWOL for a while and thought you might be in a self imposed quarantine. Glad you have the time to add and help identify the stray object. I don’t think the mysterious part in your photo came from your motor’s debris. We will come to that later.
Since you are original poster, no one could could identify it better than you. Did you have a car with CIS before? Thanks.
Tony
Old 05-28-2020, 06:44 PM
Case through bolt washer!
1978 Targa - 1980 3.0; Carrera intake; Megasquirt 2; EDIS ignition; 22/28 mm torsion bars and late Carrera sway bars; Carrera front brakes. Targa top rebuild in 2017. Suspension rebuild in 2019. Needs new paint and interior carpets.
Old 05-28-2020, 08:28 PM
Walt Fricke's Avatar
Too small for that. Got me stumped. Oil pumps don't have washers under the nuts which hold the sections together. Looks too large to be part of an oil squirter?
Old 05-28-2020, 09:29 PM
safe's Avatar
Is it the end part of a 3.6 chain tensioner? (How on earth that could have ended up in a 3.2...)
Magnus
Old 05-28-2020, 11:28 PM
Chris,
Tony
It didn't have CIS. It was a straight US 3.2L. I didn't twin plug until later.
-Chris
Old 05-29-2020, 03:45 AM
