-   -   Where is the condenser on 1975 911s (http://forums.pelicanparts.com/911-engine-rebuilding-forum/1063234-where-condenser-1975-911s.html)
hienz 06-04-2020 05:55 PM
Hi Friends'
Where is the condenser on my 1975 911s. I have been looking for it around the distributor and inside the distributor cap but still couldn't find it. My car still have the point gap.
304065 06-04-2020 07:41 PM
There is no condenser since 1968. Your car has Bosch CDI, set the point gap to achieve 38 degrees of dwell, then set the timing.
A= achtung +350 volts can kill you
B= battery +12V
C= contact = points
D= Ground
hienz 06-04-2020 08:45 PM
I was going nuts trying to find that condenser in my 75 911s. Thank you so much for quick replied and info. Thanks again.
