Rough 964 engine dimensions?
I’m looking for rough LxWxD dimensions for a 964 engine for transportation purposes.
I was hoping that someone might have one out and could take a couple of measurements. I guess I am most concerned with the height. If I could get a dimension for the total height and from the bottom of the case to the top of the fan that would be perfect. I appreciate any help you might have. Thanks! |
The long block with fan installed is approximately 28" L x 31" W x 21.5" H. That includes the carrier and transaxle studs.
Perfect, thank you!
| All times are GMT -8. The time now is 08:12 PM. |
