Mfi cam seal 49mm. Does it exist?
We are assembling a 3.0l mfi engine (rsr). The cams are 49 mm and the gasket kit contains a 47 mm seal (999 113 068 50 / radial sealing ring).
Does a 35x49x7 mm seal exist? Thank you Richard |
Yes, google the size, OD, ID and width, and you will find one for a Honda. If you can't come up with it, I have a couple here and will find them and get the size for you.
If you have a chance please do. And thank you for responding
This is a Toyota # 90311-35013. The size is 49x35x7
Thank you very much for sharing this information . Could not find it myself, saves me precious time.
Richard |
I found another seal in my own searching a couple months ago.
http://forums.pelicanparts.com/porsche-911-technical-forum/1055663-seal-mfi-camshaft-drive-49mm-later-engines.html The Toyota one looks like a good option. Thank you r lane. |
| All times are GMT -8. The time now is 09:59 PM. |
