valve spring height questions
Hi. I have some old shims. They are cerated. Use or stick with the new ones I have purchased.
Sixty seven 911S heads Lyndon http://forums.pelicanparts.com/uploa...1592812029.jpg |
I would use the original shims as they are period correct for the antique value of original.
Bruce |
cerated shims
They are old school parts from NAPA with old thinking.Better check the cc,s for compression as every time there is a valve job the compression is reduced from a stock setting.I would always clean one piston & head then cc to see what you are starting with.Adding new valve seats adds an exponential cost to the rebuild.9.3 to 1 can get to 8.2 to 1 real quick with a non Porsche shop cutting the valve seats then refacing the valve to drop it even more.A resurface of the head will gain a little back but that changes the reference of the idler shaft to the tensioner extension.Aint this fun?
| All times are GMT -8. The time now is 02:10 PM. |
