-   -   Con Rod Bolt Tightness in Cap (http://forums.pelicanparts.com/911-engine-rebuilding-forum/1065769-con-rod-bolt-tightness-cap.html)
HaroldMHedge 06-28-2020 01:24 PM
Hello,
When removing my connecting rods for an engine rebuild of my 3.2L, two bolts are loose fitting in the rod cap. Tried installing a new ARP rod bolt and I can press it in by hand. My understanding is that it typically takes more force than this. Are these rods OK to use in my rebuild?
Harold
cgarr 06-30-2020 03:21 AM
as long as there is no movement in the cap,
