-   -   Oil crossover pipe installation - frustration... (http://forums.pelicanparts.com/911-engine-rebuilding-forum/1065781-oil-crossover-pipe-installation-frustration.html)
Dauner 06-28-2020 02:31 PM
Hi everyone,
Extremely frustrated. Finishing up installation of my rebuilt 1989 911 Carrera 3.2 engine, and can't get a tool to the case side nut. Looks like I was supposed to install the pipe before the heat exchangers. Just wasnt thinking ahead. Extremely tight spacing. Can i even get in there with the special tool? Do i need to remove the left heat exchanger? I really really dont want to go loosening up gaskets and fasteners that i carefully torqued down while on the stand.
Do i have any options? I went back in both books i have been following and neither mention this as critical to install before headers... extremely frustrated with myself...
If i do need to remove or lower header, trying to think of most intelligent way to do that with removing least number of fasteneres...
Mark
boyt911sc 06-28-2020 02:35 PM
Post Pictures......
Mark,
Post some pictures where you are having some problem. You will get better responses.
Tony
Dauner 06-28-2020 03:01 PM
http://forums.pelicanparts.com/uploa...1593381590.jpg
Hi Tony, hard to show the space constraint.
I don't think I have many options...
Mark
Dauner 06-28-2020 04:49 PM
I ended up removing the heat exchanger. Couldn’t see another quick way...
Mark
boyt911sc 06-28-2020 06:48 PM
Crowfoot wrench........
Mark,
Did you try a crowfoot wrench to tighten this big nut before removing the HE? As you know by now, that oil has to be in placed before installing the heat exchangers. You are not alone, we all make this kind of mistake.
Tony
jpnovak 07-01-2020 04:09 PM
Yes, must be installed before HEs.
Walt Fricke 07-07-2020 10:06 PM
If you used a collapsible (2 piece) oil return tube there, maybe you could have gotten a tool on that big nut. I put one there just in case. It is close quarters even with the headers off.
pcardoc 07-22-2020 01:29 PM
Was going to say the same thing. Hack the oil return tube out so you have clearance and replace with a collapsible one.
