-   -   What size socket for ARP head stud kit? (http://forums.pelicanparts.com/911-engine-rebuilding-forum/1065901-what-size-socket-arp-head-stud-kit.html)
gtc 06-29-2020 03:33 PM
After a valve adjustment yesterday, I tried to check the torque on my ARP head studs. A 12mm, 12-point socket seemed about right, but wouldn't stay on the nut. Maybe it wasn't quite deep enough?
I can't remember what socket i used during assembly. I guess i'm getting old.
If anyone can point me in the right direction i'd appreciate it.
Thanks,
Graham
colingreene 06-29-2020 04:25 PM
far as i can remember thats correct.
JJ 911SC 06-29-2020 04:30 PM
Just did mine, as per "colingreene" confirmation, 12 Point - 12mm (depth socket) is it.
gtc 06-29-2020 04:56 PM
Ok, thanks guys. The end of the stud must have been too long for my 12mm wobble socket.
JJ 911SC 06-29-2020 05:29 PM
Did you use a wobble extension on you socket? If so that is the problem.
gtc 06-30-2020 10:23 AM
No, it was a socket with a wobble built in. It has a recess that was deeper than a typical shallow socket, but not enough to clear the bullet end of the ARP stud.
Side note: It's strange that deep 12 point sockets are so uncommon.
