Inspect rings or let sleeping dogs lie
I have purchased a piston and barrel set for my 2.0 S 901 \ 02
They are out off a rebuilt engine that was only run in.. No issues but more power was needed and it was converted to a 2.8 or something.
I have bought these from a reputable shop and pistons where removed whilst in the barrel.
Some have turned some in the barrel.
Question is. Will my ring gap be in the correct place when I turn turn the piston to conect it to the rod.
2nd I just have this urge to pull the pistons and check ?
Barrels were honed. New rings. Top ring land machined as it was not in spec.
Any thoughts
Lyndon
Old 05-30-2020, 12:49 AM
Once you start the engine the rings will rotate in the piston to where they want to be, or continually rotate, I don’t know.
I have opened engines before after start up and the rings are not @120 degrees any longer
Bruce
Old 05-30-2020, 03:41 AM
Location: Just a little north of 13669/Nation's capital
Send a message via AIM to brighton911
Agree with Bruce on the fact rings do rotate. If it were mine, I would be pulling the pistons out and making sure all is well. If the rings were seated, they still will be upon reassembly and you will also have full confidence in the job, as you did it.
1986 Targa Guards Red
2021 MT09 SP
Old 05-30-2020, 04:42 AM
targa72e's Avatar
I always measure, clean and inspect any used part. Keep all the parts (rings, pistons, pins and cylinders) together. I would pull the pistons and measure cylinders for ovality and taper. Check ring to piston side clearance, end gap and piston to cylinder clearance. Clean all the parts so they look like new. At that point if everything checks out you can reassemble and install.
john
Old 05-30-2020, 12:29 PM
I would also have a shop with proper equipment check the cylinder roughness. Apparently the cylinders were honed. If the surface was left too rough, the new rings will just wear out prematurely.
1990 964 Coupe
1986 Carrera 3.2 Targa
Old 05-31-2020, 09:26 AM
My last comment was assuming the cylinders were Nikasil. If they are biral with iron liners, then would naturally be honed to a much different (rougher) speciification.
P.s. This is my 1,000 post! Woo hoo!
1990 964 Coupe
Old 05-31-2020, 09:32 AM
safe's Avatar
Never trust new or used parts, check and measure. You are responsible for your build.
Rings move, and are supposed to. Only a 2 stroke have static rings due to a pin that holds them in place.
Magnus
Old 06-05-2020, 04:00 AM
This is all sound advise , If you don't know ... then you don't know . Check the info for yourself
Have fun
Drive your car
ian
Kermit, 73 RS clone,
Just Part of the Team
Chris Leydon ,Louis Baldwin ,Peter Brock ,Riche Clark
Jerry Sherman ,Rob McGlade ,Donnie Deal
Hank Clarkson ,Craig Waldner ,Don Kean ,Leroy Axel Gains
Old 06-05-2020, 09:45 AM
Ok they arrived. 17 thousand on the top ring. 2nd ring is 80 thousand. 😦
The bore has been honed but has missed some low spots. Guessing they preferred to miss a spot than enlarging the bore. ???
Lyndon
Old 07-02-2020, 05:41 PM
I have pulled all six now. I have installed my old rings out of the set that needed replacing and I have about 80 thousand gap on them. My conclusion is this shop has replaced the top ring. Fitted used 2nd rings. ( they look old as well ). The oil ring looks new as its a different type but has a gap of of 80 thousand as well.
Lyndon
Old 07-02-2020, 06:29 PM
I am reading the specs are 15 to 45 thou for the rings and 100 thou wear limit on the gaps. Wayne's book does not spec the 2.0L. ( a mistake I think ) and does not even mention the S rings at 1.5 1.5 and 4 mm
Lyndon
Old 07-03-2020, 12:52 AM
safe's Avatar
80 thousands is a lot, on the other hand it dosen't do much compression sealing. Its job is to stop the gases escaping from the top ring gap and to wipe the oil.
Magnus
Old 07-03-2020, 01:08 AM
