3.2 TDC Motronic Rotor location for dist.
I am putting back together the 87' 3.2. There isn't a slot in the distributor to adjust the timing as Motronic does that all for me in my 87'.
When installing the distributor at TDC I can either get the rotor to just before the line as shown below or just after. Since it is turning clockwise on this motor I'm guessing this is the proper placement. Can someone confirm I'm correct or is there something I'm missing? Thank you! http://forums.pelicanparts.com/uploa...1593869299.jpg |
Correct. You have the leading edge on line with the notch. Make sure you’re #1 intake rocker is loose.
Bruce |
Thank you Bruce and happy 4th! Appreciate it!
| All times are GMT -8. The time now is 04:07 PM. |
