-   -   911 Engine Shop recommendation in Michigan? (http://forums.pelicanparts.com/911-engine-rebuilding-forum/1067101-911-engine-shop-recommendation-michigan.html)
Cornerlot 07-12-2020 12:35 PM
I have an aircooled 2.7L mag case based performance engine that needs reassembly after a reseal tear down. I'm looking for an experienced and competent individual or shop in the Detroit metro area (SE Michigan) who can do the work at a reasonable cost and timing. Cases were not split, and at this point no machining should be needed. Most parts are on hand. Heads are freshly rebuilt, so assembly of pistons/rings/cylinders/heads/cams/chains/etc. is what I have in mind.
ANY RECOMMENDATIONS?
Lyle O 07-12-2020 03:25 PM
Automotive Techniques in Novi. They have done several projects for me, including engine rebuild and “enhancements” and are top-rate. Don’t know of anyone better around here. They are the best.
Cornerlot 07-12-2020 04:06 PM
Shops
I'm familiar with big shops like Automotive Techniques and Arbormotion, Munk's too. A/T is probably the choice of the 3, but was hoping to find a low profile shop or experienced individual.
LUFTKUL 07-20-2020 05:45 AM
I trust Tim Pott's knowledge and experience at AT in Novi. Sebastian's crew at ArborMotion is good and he has a really nice facility, but Tim isn't there anymore...
