Where to recondition 3.2 crankshaft
I bought a used 3.2 crankshaft to eventually replace the one in my '84 with a damaged snout. I want to go ahead and get it reconditioned so it's ready when the time comes, but I'm in no hurry.
Where are the recommended go-to places for this? Is CCR still working out of TX? Marine Crankshafts in CA? Others? |
I liked Armando and CCR. Seeing you’re not in a hurry, quality is choice.
Might repair your 84 nose.... Bruce |
Can anybody confirm up to date contact info for CCR?
I’ll give it to you on PM
Bruce |
Marine Crankshaft in LA.
I just had a great experience with David at Marine Crankshaft Repair. Highly recommend him and his work. Jim
I've used Marine Crankshaft with good results.
regards, al |
crank
+1 for Marine crank in O.C. in calif.
I used Mile High Crankshaft Repair in Denver after spinning a rod bearing.
I’ve used CCR and Marine and they’re both good. Of the 2, I have slight preference for CCR though.
Like I said earlier, and others have said. Marine Crankshaft is the place to go. NO drama, Reasonable turn arounds, high quality work. An actual proper business.... Far from a one man band.
Not saying Armando does not do great work, but as a business we can't screw around, and have a situation like Charles at LN had..... Search the forums, not just his one, and see if you want to send your crank there... Cheers |
| All times are GMT -8. The time now is 08:14 AM. |
