911 valve spring compresser
Hi, anyone know if spring compressor p71 will work on exhaust valves for 3.0 911 engine? the number for exhaust valve compressor is p7e thanks john
Can’t say for sure, but I suspect the geometry of the valve to cover stud is different on the exhaust side. Probably why there’s a different number tool.
P7E and P7I........
John, It will not work. That is the reason why they make two (2) different tools. One for intake and the other one for exhaust. Do you need a set? Tony |
I successfully used the INTAKE tool on the Exhaust valves, but I had to McGyver it though it worked.
I later got the exhaust tool, which is much easier. Serge |
| All times are GMT -8. The time now is 04:16 AM. |
