 Are the leak always coming from the bottom and not the top? |
 Ed Mayo from PCA says 62.058 mm. |
 bcgreen, I think the only place sealant is needed is between the O-ring and the case.  If oil gets past that, then another approach is needed. I don't know what yamabond is. I would suggest curil-T because 1) it seals quite effectively 2) it is used around the nose bearing O-ring per Wayne's book, so it is compatible with all materials in the interface, and 3) it is completely reversible (just wipe off with alcohol; takes a while, but it will come off). Anything that sticks & cures, especially if it is an epoxy, is not readily reversible without engine disassembly. The protruding part of the nose bearing measures 60mm for my 3.2, which is the dimension that matters for your project. The diameter of the bearing portion is 65mm, checked with a caliper, not a mic - but that is somewhat irrelevant. Do you need a ring & washer for pressing the clamp ring into the case, or do you have suitable parts available? |
 These statments from a posting of whether to use Sikaflex or Yamabond. "Yamabond is actually three-bond if you go to the three bond site you’ll find all the info you need. Been using three bond for many years on various motorcycles et good stuff." "Yamabond never hardens completely and if it's good enough to seal 2 stroke case halves together I think it will do the trick." I think I would need that ring and washer for pressing. |
 I'll make a ring & washer for you to use.  I will get them in the mail this week. |
 So you don't need my particular bearing diameter? |
 In the nose bearing thread, the minor diameter was posted as 60mm ... I imagine that is the part that sticks out of the case, and it matches my bearing.  Trying to avoid you sitting there waiting on parts lost in the postal service morass. |
 Don't mind waiting as there is the interior that I am finalizing as well. |
| All times are GMT -8. The time now is 08:48 AM. |
