PMAC
Guest
Posts: n/a
Used Mahle pistons & cylinders
Hi,
Can Mahle pistons and cylinders be mixed and matched if they are from the same diameter group. For instance could I buy a good used set of pistons and a good set of used cylinders and use them with no problems? What kind of prep would be needed?
Thanks,
Pat
Old 04-19-2003, 05:31 PM
Author of "101 Projects"
Wayne 962's Avatar
You need to match Nikasil and Alusil (Mahle made both), and also height groups on the cylinders. If you are balancing your engine, the weight group on the piston is not that important...
-Wayne
Old 04-19-2003, 06:50 PM
PMAC
Guest
Posts: n/a
Thanks for the response.
I was thinking nikasil when I wrote the post. So mixing nikasil pistons and cylinders from the same groups but different sets is ok, right?
I know I've read this before but how do you tell Nikasil from Alusil if they both say Mahle? Isn't the Nikasil cylinder coating slightly magnetic?
Old 04-19-2003, 08:36 PM
Warren Hall Student
Bobboloo's Avatar
The Alusil cylinders are a light alluminum color. When you look inside the cylinder it is a light foggy color. The Nikasil cylinders are darker and more shiny like nickel on the inside.
Make sure to check ovality (problem with Alusil) and the top ring land (problem with old Nikasil pistons) before you put down your cash. There's a lot of garbage for sale out there.
Bobby
_____In memoriam_____
Warren Hall 1950 - 2008
_____"Early_S_Man"_____
Old 04-19-2003, 11:02 PM
a magnet will 'drag' a slight amount with Nikasil cylinders. A very slight magnetic attraction. From what I am told, Alusil wont.
Chris
Old 04-20-2003, 10:13 PM
