-   -   2.2T rebuild (911/07) Only Deves rings available? (http://forums.pelicanparts.com/911-engine-rebuilding-forum/1072555-2-2t-rebuild-911-07-only-deves-rings-available.html)
Optimusglen 09-08-2020 02:14 PM
All, I'm in the process of getting my 2.2T back together. I had ordered piston rings else-ware but they came as 1.5-1.5-4 and I need 1.5-2-4. It looks like our host only offers Deves rings for this application but I thought I read that those were bad news.
Any insight?
edit: I should have put it in the title but I have the KS pistons
Flat6pac 09-08-2020 03:17 PM
Check with EBS
Bruce
Optimusglen 09-08-2020 03:22 PM
I looked there as well, nothing in the 1.5-2-4 KS sizes
VFR750 09-08-2020 04:15 PM
Check with total seal. They make rings for many different engines. Running them on my 3.0 with JE pistons.
reclino 09-08-2020 04:20 PM
Call Total Seal, they are very helpful on the phone, will make a custom ring package for you and give you the part number, then you call one of their distributors to order that part number. Very impressive.system they have set up.
