GT3 rod bearings
I have 2 choices for the GT3 rod bearings for my 3.0 engine, part # 996 103 121 94. Glyco or Genuine Porsche. The Glyco set says Germany and the Genuine Porsche bearing carries the part# and the Porsche triangle symbol. Is this Glyco bearing OK, or do I run from it. I had heard that the GT 3 bearing was reliable, but which one. Thanks, Bopb
Old 09-03-2020, 05:30 PM
I would rather be driving
jpnovak's Avatar
Clevite from Automobile Associates.
Old 09-03-2020, 05:58 PM
I have always used the factory bearings, I heard from another pelican that the glyco red box set do not measure the same clearance as the factory bearing as in much less with the same size big end dimension, at 2.205 I have always ended up with.0028-.003 on a typical strong std journal with the Porsche bearings
Mike Bruns
The two most useless things to a driver are the braking distance behind you and nine-tenths of a second ago.
I don’t know if Apples to Apples, but for my 3.2 Rebuild, I (ultimately) used Clevite 77 bearings for my Rods, and GT3 Reds for my mains. Lot’s of learning curve delays, as summarized in my thread(s) below. Embedded in this thread is another thread started by me, so there is commentary inclusive for both Rods and Mains.
Rod Bearing alignment of edges off
I now have 1400 miles on my rebuild, with things so far generally behaving as I had hoped and spec’d.
Mark
1989 911 Carrera 3.2
2009 Audi A4 2.0TQA
2017 BMW X3
2007 BMW 328xi
1971 BMW R60/5
Old 09-04-2020, 08:58 AM
JackkTheMackk's Avatar
As someone who has just had the red glyco box GT3 bearings, mahle/clevite, and the genuine porsche ones all in hand, I would only use the genuine Porsche 996 GT3 bearings. They are different than the glyco ones and the mahle/clevite are too thick (measured them in the micrometer).
Clearances I got on std/std
Glyco: .0021”
AA Mahle/Clevite: .0013”
GT3 genuine: .0028”
If you are interested, I will sell you my AA bearings. They were too tight for my build but will be fine for a stock rebuild.
‘70 911E
‘82 911 SC Targa
‘86 944 Turbo
‘90 OM606 Swapped SWB 300GD
IG: @JackSchroederCreative
Old 09-04-2020, 09:59 PM
It's a 914 ...
stownsen914's Avatar
Interesting that Clevite bearings wound up at .0013". The ones I got for my build ended up around .0025" I believe (measured by my machine shop, not by me).
I understand that the Clevite bearings come in an "extra clearance" version as well. I got the regular ones.
Old 09-05-2020, 04:44 AM
I had no idea they came in that option. I had a friend at a shop order them for me.
‘70 911E
‘82 911 SC Targa
‘86 944 Turbo
Old 09-05-2020, 08:08 AM
VFR750's Avatar
I did genuine Porsche GT3 rod bearings 17,000 miles ago.
Expensive but no issues 5 years And maybe 2000 track miles later.
Old 09-05-2020, 02:06 PM
@r lane
I used GT3 rod bearings for 3.0 SC which I recently completed. You can see little marks where the bearings were measured, giving me some confidence that they should be in spec. They also come well packaged in their own plasic bag so as not to get damaged during shipping.
The part number I ordered was 996-103-121-94. They come as individual half-bearings, not as a set.
I originally ordered the cheap Glyco bearing from our host but I was not happy with how they were packaged by the manufacturer, and I read many post about those being out of spec. The packaging on the Glyco bearings said they were made in South Africa, not Germany. I returned them and spent the money on Porsche bearings.
-1978 911 SC
-2002 996 Turbo
-2015 WRX STi [SOLD]
Old 09-09-2020, 03:08 PM
