JoeMag's Avatar
Race motor -- ratio valve seat ID to valve OD
Anyone have guidance here?
...and how about valve seat ID to intake port ID?
Old 09-21-2020, 09:55 AM
Ollies930's Avatar
Way too many variables, one size does not fit all. Engine rpm, displacement, compression ratio, valve size, carb, EFI, turbo, all play a role in determining the appropriate size. And porting a cylinder head is not as simple as opening the port and valve seat to a certain diameter. Better to discuss your goals and expectations with a good head porter like Bill at Xtreme. He will know what works and be able to get you close to a winning combination.
Old 09-21-2020, 05:22 PM
