JoeMag's Avatar
Max hp from 993 heads?
...anyone know max hp you can get with 993 heads?
Old 09-14-2020, 02:47 PM
smokintr6's Avatar
Send a message via AIM to smokintr6
Stock ones?? or ?????
I did 300 Wheel Hp with them, but the engine was not stock.... I'm guessing with a turbo they will do waaaaaay more.
Old 09-14-2020, 03:47 PM
Racer
winders's Avatar
The question shouldn't really be how much power can you get from 993 heads. It should how long will they last at the heat and stress levels of a high output engine.
You can get 110 HP per liter with 993 heads. They will last longer than 964 heads because they use a better aluminum alloy. But, they are still going to crack eventually.
Scott Winders
PCA GT3 #3
2021 & 2022 PCA GT3 National Champion
2021 & 2022 PCA West Coast Series GT3 Champion
Old 09-14-2020, 03:56 PM
head life
Yes,the head life is the RR factor.Ciao Fred
Old 09-14-2020, 04:21 PM
RR Factor
RR is ROLLSROYCE.
Old 09-14-2020, 05:37 PM
JoeMag's Avatar
... talkn stock heads w 50mm intake and 43.5mm exh valves. 400+ hp seems high. Best I’ve seen w 993 rs heads was a Roth sport slide valve one at around 420 crank (not sure if other head work done)
Old 09-15-2020, 06:49 AM
We were lucky to get 30 race hours out of 4 different 964 sets over 3 years time, north of 400 hp, we have 150 hrs on the Xtreme castings and no problems
Mik Bruns
The two most useless things to a driver are the braking distance behind you and nine-tenths of a second ago.
Old 09-16-2020, 04:48 PM
Racer
winders's Avatar
Mik Bruns
This is exactly why I went with Xtreme heads for my race engine build. Expensive....but I am saving money in the long run.
Ok, the improved performance and heat handling abilities were important factors too......
Scott Winders
PCA GT3 #3
Old 09-16-2020, 05:53 PM
